Start Easy Data Transform.
Drag a data file you want to transform onto Easy Data Transform. Any sort of table or list should be fine. For example a .csv file or an Excel .xlsx/.xls file.
You will be asked for a file to write to. You can change the file type.
You can also specify the delimiter and encoding for the output item in the Right pane.
You can save your transforms to use again with File>Save.
Have a play!
Tips:
•You can also paste in data from the clipboard (for example, a table from a web page).
•The Sort and Filter transforms take account of dates, numbers and text. You can define what date formats are recognized in the Preferences window.
•Comparisons of text are always sensitive to case. For example, "CASE", "case" and "Case" are treated differently. You can use the Case transform to change case.
•Comparisons of text are always sensitive to whitespace (e.g. spaces and tabs). You can use the Trim transform to remove leading and trailing whitespace.
•The contents of input data files are not saved in Easy Data Transform.
We are very interested in your feedback, so please contact us to ask a question, report a bug or request an enhancement.
