Quick start guide
Quick start guide
quick-start-0
Drag a data file you want to transform onto Easy Data Transform. Any sort of table or list should be fine. For example a .csv file or an Excel .xlsx/.xls file.
quick-start-1
quick-start-header
quick-start-case
quick-start-case-b
quick-start-case-2
quick-start-sequence
quick-start-stack
quick-start-stack2
quick-start-export
quick-start-output-1
You will be asked for a file to write to. You can choose amongst multiple file formats. Select CSV file.
choose-output-format
quick-start-output-2
quick-start-output-3
You can save your transforms to use again with File>Save.
Have a play!
Tips:
•You can also paste in data from the clipboard (for example, a table from a web page).
•Comparisons of text are always sensitive to case. For example, "CASE", "case" and "Case" are treated differently.
•Comparisons of text are always sensitive to whitespace (e.g. spaces and tabs). You can use the Trim transform to remove leading and trailing whitespace.
•The contents of input data files are not saved in Easy Data Transform.
We are very interested in your feedback, so please contact us to ask a question, report a bug or request an enhancement.
