Quick start guide
Quick start guide
Easy Data Transform
Auto Run checked
transform csv file
extract header
transform case
covert case
convert to upper case
data transform pipeline
merge CSV files
stack CSV files
export CSV files
merge CSV files
output to CSV
export CSV
CSV delimiter
Have a play!
Tips:
•Check the show advanced check box in the Right pane to see all the available transforms.
