Meta Information
Navigation:  Reference >
Meta Information
Add meta data
Meta Information
$(ComputerName)
The name of the computer.
MyComputer
$(CurrentDate)
The current date, in ISO format.
2020-08-18
$(CurrentDateTime)
The current datetime, in ISO format.
2020-08-18T18:00:00
$(DataColumns)
The number of columns in the dataset (not including meta data).
10
$(DataRows)
The number of row in the dataset (not including meta data).
10,000
$(DataValues)
The number of columns x rows in the dataset (not including meta data).
100,000
$(FileCreatedDate)
The date the file was created, in ISO format. Only available for file input.
2020-08-18
$(FileCreatedDateTime)
The datetime the file was created, in ISO format. Only available for file input.
2020-08-18T18:00:00
$(FileName)
The name of the file, including it's extension. Only available for file input.
myfile.csv
$(FilePath)
The full path (location) of the file. Only available for file input.
/Users/andy/Documents/myfile.csv
$(FileSheetName)
The name of the sheet. Only available for Excel files.
Sheet1
$(FileSizeBytes)
The size of the file in bytes. Only available for file input.
1,234,567
$(FileUpdatedDate)
The date the file was last updated, in ISO format. Only available for file input.
2020-08-18
$(FileUpdatedDateTime)
The datetime the file was last updated, in ISO format.  Only available for file input.
2020-08-18T18:00:00
$(UserName)
Andy
•Stamp
