Quick start guide
Quick start guide
Easy Data Transform
Drag a data file you want to transform onto Easy Data Transform. Any sort of table or list should be fine. For example a .csv file or an Excel .xlsx/.xls file.
transform csv file
extract header
transform case
covert case
convert to upper case
data transform pipeline
merge CSV files
stack CSV files
export CSV files
merge CSV files
You will be asked for a file to write to. You can choose amongst multiple file formats. Select CSV file.
output to CSV
export CSV
CSV delimiter
Have a play!
Tips:
•You can also paste in data from the clipboard (for example, a table from a web page).
•Comparisons of text are always sensitive to case. E.g. "CASE", "case" and "Case" are treated differently.
•Comparisons of text are always sensitive to whitespace (e.g. spaces and tabs). You can use the Trim transform to remove leading and trailing whitespace.
•The contents of input data files are not saved in Easy Data Transform.
•You can perform the same set of transformation on multiple files using Batch processing.
We are very interested in your feedback, so please contact us to ask a question, report a bug or request an enhancement.
