<< Click to Display Table of Contents >> Navigation: Reference > Meta Information |
Meta Information |
Description |
Example |
$(ComputerName) |
The name of the computer. |
MyComputer |
$(CurrentDate) |
The current date, in ISO format. |
2020-08-18 |
$(CurrentDateTime) |
The current datetime, in ISO format. |
2020-08-18T18:00:00 |
$(DataColumns) |
The number of columns in the dataset (not including meta data). |
10 |
$(DataRows) |
The number of row in the dataset (not including meta data). |
10,000 |
$(DataValues) |
The number of columns x rows in the dataset (not including meta data). |
100,000 |
$(FileCreatedDate) |
The date the file was created, in ISO format. Only available for file input. |
2020-08-18 |
$(FileCreatedDateTime) |
The datetime the file was created, in ISO format. Only available for file input. |
$(FileName) |
The name of the file, including it's extension. Only available for file input. |
myfile.csv |
$(FilePath) |
The full path (location) of the file. Only available for file input. |
/Users/andy/Documents/myfile.csv |
$(FileSheetName) |
The name of the sheet. Only available for Excel file input. |
Sheet1 |
$(FileSizeBytes) |
The size of the file in bytes. Only available for file input. |
1,234,567 |
$(FileUpdatedDate) |
The date the file was last updated, in ISO format. Only available for file input. |
2020-08-18 |
$(FileUpdatedDateTime) |
The datetime the file was last updated, in ISO format. Only available for file input. |
$(UserName) |
Andy |
