Quick start guide
Quick start guide
Easy Data Transform
Drag a data file you want to transform onto Easy Data Transform. For example a .csv file or an Excel .xlsx/.xls file. XML, JSON, fixed width and vCard formats are also supported.
transform csv file
extract header
transform case
covert case
convert to upper case
data transform pipeline
Select both input items (by dragging a box around them or using Cmd+click).
merge CSV files
stack CSV files
export CSV files
merge CSV files
output to CSV
export CSV
CSV delimiter
Have a play!
Tips:
Check the show advanced check box in the Right pane to see all the available  transforms.
You can also paste in data from the clipboard (for example, a table from a web page or Word document).
The Compare Cols, Filter, If and Sort transforms take account of dates, numbers and text. You can define what date formats to recognize in the Preferences window.
Comparisons of text are always sensitive to case, unless stated otherwise. E.g. "CASE", "case" and "Case" are treated differently.
Comparisons of text are always sensitive to whitespace (e.g. spaces and tabs), unless stated otherwise. You can use the Whitespace transform to remove leading and trailing whitespace.
The contents of input and output data files are not saved in Easy Data Transform, only their locations.
