Quick start guide
Quick start guide
Easy Data Transform
Auto Run checked
transform csv file
extract header
transform case
covert case
convert to upper case
data transform pipeline
merge CSV files
stack CSV files
export CSV files
You can also add an output item to automatically write a dataset to file whenever it changes.  With the Stack item selected, click To File at the bottom of the Left pane. You may need to scroll to see it.
merge CSV files
output to CSV
export CSV
CSV delimiter
Have a play!
Tips:
•You can insert a new transform between existing items by selecting the connection between the items and then clicking the transform button in the Left pane.
•To be more productive with Easy Data Transform see the expert tips.
