Quick start guide
Quick start guide
Start Easy Data Transform.
If the Choose Edition window appears, leave the edition as Advanced and click OK.
Choose edition window
If the Free Trial window appears, click Continue free trial.
Free trial window
If the Getting Started window appears, click I got this!
Getting started window
You should now see the main window.
Easy Data Transform
Auto Run checked
Download 2 example data files from our website by clicking these 2 links:
•mailout1.csv
•mailout2.csv
Drag mailout1.csv from your download folder onto the Center pane of Easy Data Transform.
transform csv file
Close the How To Add Transforms window that appears.
extract header
Hover over the transforms in the Left pane to see tooltips explaining what they do. Click on the ? next to a transform button for more details.
Note that the emails in the dataset Email column have a mix of upper and lower case. Lets fix that.
Ensure the input item is selected and click on the Case transform button to add a Case transform.
transform case
covert case
In the Right pane, check the Email column and set Change case to to Lower case. The transformation will be carried out as soon as you have stopped making any change in the Right pane for 2 seconds (you can change this in the User Interface tab of the Preferences window).
convert to upper case
Note that we have only changed the dataset in memory. We have not modified the input file.
You can add more transforms in a sequence of transforms to perform complex manipulations, step by step.
data transform pipeline
Some transforms require more than one upstream dataset. For example, to stack two datasets, one on top of the other (vertically):
•Drag mailout1.csv and mailout2.csv files onto the Center pane.
•Click the Stack transform button (you may need to scroll down the Left pane to see the button).
merge CSV files
The tables are now stacked one on top of the other in a new dataset item. You can choose to match the columns by Header name or Column number. Because both files have the same headers, it doesn't matter here.
stack CSV files
Any changes to input options will cause the input file to be automatically re-read. Any changes to upstream datasets or transform options will be automatically propagated 'downstream'.
export CSV files
You can also add an output item to automatically write a dataset to file whenever it changes.  With the Stack item selected, click To File at the bottom of the Left pane. You may need to scroll down to see it.
merge CSV files
You will be asked for a file to write to. Choose a convenient location, such as the Desktop folder, and select CSV file.
output to CSV
export CSV
Have a play!
Tips:
•You can input a folder of files using the From Folder button in the Left pane.
•As well as stacking two datasets, you can also Join them, side-by-side, by a common ('key') column or row number.
•You can insert a new transform between existing items by selecting the connection between the items and then clicking the transform button in the Left pane.
•The Advanced Edition of Easy Data Transform has powerful visualization capabilities.
•To be more productive with Easy Data Transform see the expert tips.
