12. Use a schema to handle changes in columns in an input.
20. Display the currently selected value from in the data table in a separate window by pressing the Space key or selecting Show Value... from the right click menu. This is useful for inspecting values that are too wide to be displayed in the data table.
30. Learn keyboard shortcuts. For example, you can quickly change selection in the Center pane using arrow keys with the Cmd key.
45. Hold down the Cmd key when adding a new transform or output item to add it to the bottom left or the current canvas. Otherwise, it will be added to the right of the currently selected item(s). This works when inserting by clicking a button in the Left pane, typing a transform name or adding from the right click menu.
49. Change focus between the Center and Right panes using Option+[ and Option+].
50. Check the gray Left pane buttons when not available checkbox in the General tab of the Preferences window for Left pane buttons to be disabled until the appropriate items in the Center pane are selected.
