To get this dataset:
•Drag the two dataset files onto the Center pane of Easy Data Transform.
•Select the two datasets using Cmd+click.
•Click the Stack transform in the Left pane.
•Click the Join transform in the Left pane.
•Set both Top key column and Bottom key column to the common ('key') column.
If you just want to join row N of one dataset to row N of another dataset, you set By to Row in the Join transform.
If you only want one column from the second dataset you can use the Lookup transform.
If you want to find key values that are in one dataset but not the other (an 'anti-join') you can use the Subtract transform:
