<< Click to Display Table of Contents >> Navigation: Reference > Transforms > Rename Cols |
Rename column headers.
Rename columns 'first' to 'First' and 'last' to 'Last':
•Click the
button to change all the names to lower case.
•Click the
button to change all the names to upper case.
•Click the
button to change all the names to title case.
•Click the
button to to replace name text using text, exact text or Regular expression matching.
•Click the
button to add text to the front or back of all the names.
•Click the
button to add '-2', '-3' etc to duplicate names, to make them unique.
•Click the
button to change all the names back to their original name.
•Click the
button to copy names to the clipboard.
•Click the
button to paste from from the clipboard.
•Type text into the Filter field to temporarily hide columns whose old or new names do not contain this text.
•Column filtering is sensitive to whitespace, but not case.
•If you are pasting names, the format expected is Comma delimited text. E.g.: name1,name2,name3.
