Quick start guide
Quick start guide
Easy Data Transform
Drag a data file you want to transform onto Easy Data Transform. Any sort of table or list should be fine. For example a .csv file or an Excel .xlsx/.xls file.
transform csv file
extract header
transform case
covert case
convert to upper case
data transform pipeline
merge CSV files
stack CSV files
export CSV files
merge CSV files
You will be asked for a file to write to. You can choose amongst multiple file formats. Select CSV file.
output to CSV
export CSV
CSV delimiter
Have a play!
Tips:
•Comparisons of text are always sensitive to whitespace (e.g. spaces and tabs), unless stated otherwise. You can use the Trim transform to remove leading and trailing whitespace.
