Drag a data file you want to transform onto Easy Data Transform. Any sort of table or list should be fine. For example a .csv file or an Excel .xlsx/.xls file. XML, JSON, fixed width and vCard formats are also supported.
You can also specify the Delimiter and Encoding for your CSV files in the Right pane.
Have a play!
Tips:
