<< Click to Display Table of Contents >> Navigation: Reference > Transforms > Concat Rows |
Concatenate every 2 rows to 1:
Concatenate values until empty:
Concatenate values while not starting with 'ID':
Concatenate consecutive rows with the same OrderId:
•Set Mode to:
oFixed to concatenate a fixed number of rows from the current dataset to make each new row.
oVariable to concatenate values while or until a match to make each new row.
oBy key to concatenate consecutive rows with the same value in a key column to make each new row.
•Set Create 1 row from every to N, to concatenate every N rows into 1 row (Mode=Fixed only).
•Set Concatenate to Until or While to keep concatenating until/while a match is found for Matches and Value (Mode=Variable only).
•Check case sensitive to use case sensitive matching for text (Mode=Variable or By Key only).
•Set New row value depending on what you want to do with the value that denotes a new row (Mode=Variable only).
•Uncheck repeat key column to keep only the first key column (Mode=By Key only).
•Use Sort before this transform if you need to change the row order.
