Find columns by filtering
Filter on column name
Check/uncheck multiple columns by criteria
If there are multiple columns, you can check or uncheck them by various criteria in the Select Columns window. For example it can check or uncheck all the empty columns.
Select columns by criteria
Remove multiple empty columns
ignore-empty-cols-mac
Remove multiple columns
•Add a Remove Cols transform.
•Click the Clear button.
remove-multiple-columns-mac
Rename multiple columns
•Add a Rename Cols transform.
•Click Close.
rename-multiple-columns-mac
•Handle large datasets
